Bericht
door Bastiaan » 17 dec 2013, 14:52
Hoe zou dit gedaan moeten worden voor een E39 uit 2003. Ik weet dat er bij een E46 een paar handelingen gedaan moeten worden via de sleutel en knopjes op de cockpit.
Update:
Heb wat gevonden op internet:
BMW Oil Service reset for 2001 ~ current
No need for reset tool for 2001+ model by: Moko
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
