- Spoiler: Laat zien
- Continued on the front.
Almost all the parts on the front are mounted.
Got all the parts into the trunk again.
It's getting close..
Changed the airfilter.
Painted the Turner plates.
The M3 has a reinforcement from each side of the chassis to the diff. I had to make mounting points for this on the sedan. I studied the M3 and welded together a similar part. Also used a couple of nut threads to position the part, it also gives additional strength even thought that probably isn't necessary.
Epoxied.
The part with epoxy applied.
Part installed and painted. I will drill and make threads for the bolt when I get the rear suspension mounted.
More parts.
Got the M3 fuel tank mounted. Fit was perfect.
Bought wheel studs. These turned out to be a little to long on the hub thread, had to cut 20 studs and sand the end... not funny..
New bolts for the subframe.
Ready for mounting.
Almost there..
Installed!
There was a thick layer of some sort of rust protection on the rear suspension support, it looked very dirty. It was impossible to wash off so had to grind the part down to the metal.
Here you can see why I had to make the mounting points on each side of the chassis. It was for this support.
Marking up where to drill.
The driveshaft mounted.
Exhaust washed and ready for the car.
Heat shield and plastic cover installed.
More tomorrow.. cheers!:dave:
Cleaned the rear hubs and applied a layer og zink paint. This should keep the rust away at least for a while. Im doing this to the front as well.
Got the roll bar and front plate mounted.
Heat shields on.
Putting on a new exhaust tip, gave the old one to my dads car when he dented his.
Everything except the plastic shields mounted and connected.
Also did a bit of touch up on some of the parts.
E46 M3 SMG SEDAN PROJECT
Re: E46 M3 SMG SEDAN PROJECT
Het loopt gesmeerd. En wat een liefhebber deze kerel, alles wordt gereinigd en bescherm. Dit is nou echt porno voor auto liefhebbers.
Wauw, ik vind het erg knap als je zoiets kan en ook nog eens het geduld ervoor op kan brengen!
Ik zou niet wachten om te kunnen rijden als ik hem was
styling, hoe moet het dan wel? : ↑ :~
Wat een superdikke sedan is dat geworden zeg, damn
MIjn god.... mijn volgende auto MOET en ZAL in dezelfde kleur zijn!!!
Verrek, BMW rijd toch ook wel lekker!!!
heeft ie nou ook coupé-achterlichten?
Ja. Complete M3 Coupé voorkop en nieuwe OEM M3 Achterschermen.
Heb wel m'n bedenkingen bij de achterklep, dat was namelijk origineel een CSL Replica voor Sedan die hij heel erg heeft moeten aanpassen, lijkt nu niet echt meer op de OEM style. Beter had ie een OEM CSL gekocht.... En natuurlijk de LEDs, aangezien CSL altijd LED heeft.
Casette speler is idd beetje minder, maar ach, je bouwt zo'n auto natuurlijk niet om muziek te luisteren....
Eerste fotoshoot is trouwens ook een feit.
Deze is zo vet dat hij niet tussen Spoilers gaat verdwijnen
Wat een gafe bak is het geworden zeg! Alleen wel jammer dat hij zoveel geld uitgeeft aan dit project en geen Silvervisions monteert
Echt geniaal dit project! stoelen vind ik persoonlijk minder, ik was voor OEM M3-stoelen gegaan. Verwarmd en elektrisch verstelbaar :~
Verder helemaal geweldig, lijkt me zo mooi om ooit nog eens zo'n unieke auto te kunnen sturen!
Volgens mij vind ik 'm gewoon mooier dan de M3 coupé! (h)
