Ik heb een 530d e60 uit 2003, deze heeft een grote beurt gehad waarbij alles bijna vervangen is, meeste heb ik zelf gedaan.
Nu wilde ik het een en ander resetten, en de volgende heb ik op internet gevonden:
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
Nu heb ik dit gedaan, alles is gelukt, op één ding na niet, namelijk:
de achterremblokken konden nog 20000 km mee, maar na deze te resetten, gaf hij nu dat het -25000 km is geworden en meteen naar de bmw-dealer moet gaan, dus dat ik al 25000 km te laat ben met mijn achterremblokken te vervangen.
Nu kan ik deze ook niet meer resetten, hij weigert gewoon.
Weet iemand hier raad op, of hoe ik dit ongedaan kan maken en wel gewoon kan resetten??
alvast bedankt
Reset e60 uit 2003
Re: Reset e60 uit 2003
Ik heb hetzelfde probleem gehad,, het bij mij bleek het de slijt indicator te zijn,,
Ook al zag die er niet beschadigd uit,, was ie tog geactiveerd...
Na een nieuwe erin gezet te hebben, was m'n melding wel te resetten
maar was de slijtindicator ijzer op ijzer?
nope,, hij zag er onaangetast uit en toch had ik een melding
Bij km-stand boven de 300.000 kan het gebeuren dat de km-stand voor motorolie niet meer te re-setten is. (Het lukt wel, maar na ca 30 s verandert de stand weer automatisch naar 0 km. (Alle andere intervals blijven wel te re-setten)
Onder andere op you-tube is te vinden dat dit blijkbaar een software beperking is. Met de juiste programmeersoftware is de komplete aanduiding voor motorolie te verwijderen, je moet dan de eerstvolgende beurt ouderwets op een kaartje noteren.
Ik ben wel benieuwd of er een nieuwere versie van de software is , die deze beperking niet heeft.
Pjotr
e60- 525d- 370.000 km
Pjotr
Die is er niet. We zullen het hiermee moeten doen.
