Leakage around accelerator pedal
Frederique
Bericht door Frederique » 02 jan 2025, 15:37
Since a few weeks there is water on the floor around the accelerator pedal. Only when it rains. As you can see on the pictures, under the bonnet the fabric is also wet and there is some water on the floor under the bonnet. Where the left front door hinges, I see water dropping at the bottom (see arrow in picture). Where you see red, it’s wet. Does anyone have an idea what the cause can be? Thanks!
Re: Leakage around accelerator pedal
Bericht door Source » 05 jan 2025, 12:15
Difficult to say cause with leakage it can be from anywhere.
What is your location?
Leon1980
Bericht door Leon1980 » 27 jan 2025, 17:03
Maybe the foil on the inside of the door is not sealing anymore? I had the same at my right rear door.
New screen in the door and it was solved
