Beste ik zoek de kleuren( kleurcodes) van de draden van de radio. ik zou een ingintion plus moeten hebben en een min draad. deze is bruin dacht ik maar ik zou dus een plus moeten hebben wanneer je je contact aandraait.
bedankt
mvg
Snelle hulp met draden
Re: Snelle hulp met draden
autos vanaf 2001/2005 bm54 conector met vlakke pinnen!
Pin No. / Wire Color / Function
Large Black Plug x18126
1 / Blue-Black / Right Rear + output to amp (twisted with 5)
2 / Blue-Red / Right Front + output to amp (twisted with 6)
3 / Yellow-Red / Left Front + output to amp (twisted with 7)
4 / Yellow-Black / Left Rear + output to amp (twisted with 8 )
5 / Blue-Black / Right Rear + output to amp (twisted with 1)
6 / Blue-Red / Right Front + output to amp (twisted with 2)
7 / Yellow-Red / Left Front + output to amp (twisted with 3)
8 / Yellow-Black / Left Rear + output to amp (twisted with 4)
9 / White-Yellow bands / I-bus?
10 / White-Brown / Mute from phone?
11 / White-Green / ?
12 / Brown / Ground
13 / White / Remote on-off to amp
14 / Grey-Red / Dash illumination (dimmer)
15 / Red-Green / +12v from battery (not switched)
16 / Violet-White / +12v from ignition (ACC and RUN)
small white plug x13598
1 / / No function
2 / White-Brown / Audio common from 6CD player
3-7 / / No connection
8 / White-Red / Audio Left Channel from 6CD player
9 / White-Blue / Audio Right Channel from 6CD player
10 / / No Connection
11 / NAV / TV Audio +
12 / NAV / TV Audio -
NEW Small black plug: x13649 plug
1 / Tape left +
2 / Tape left -
3 / Left Connection for AUX Input
4 / Right Connection for AUX Input
5 / NAV / TV Audio +
6 / White-Black / Phone audio + Positive
7 / Tape right +
8 / Tape right -
9 / No connection
10 / AUX Input Ground
12 / Brown-Black / Phone Audio - Groundv
pin bezetting 99/01 (ronde pinnen)
1 / Speaker - Front Left (+)
2 / Speaker - Front Right (+)
3 / Speaker - Rear Left (+)
4 / Telephone Mute
5 / +12v from ignition (ACC and RUN)
6 / Speaker - Rear Right (+)
7 / DAC - i-bus
8 / Speaker - Front Left (-)
9 / Back Up (?) (terminal 30 - Fuse F56)
10 / GAL - speed signal
11 / Speaker Front Right (-)
12 / Speaker Rear Left (-)
13 / Nighttime Illumination Signal
14 / Speaker Rear Right (-)
15 / Ground
16 / Auto Antenna - diversity
17 / Not Used (LAC)
x18805:
Pin No. / Function
1 / Audio Cassette Right (+)
2 / Audio Cassette Right (-)
3-4 / No connection
5 / Low Frequency Signal (-) - Nav Control Module / Video Module
6 / Audio Cassette Left (+)
7 / Audio Cassette Left (-)
8-9 / No Connection
10 / Low Frequency Signal (+) - Nav Control Module / Video Module
x01037
Pin No. / Function
1 / Low Frequency Voltage Signal CD Changer Left
2 / Low Frequency Voltage Signal CD Changer Right
3 / Shield - audio shield
4-5 / No Connection
6 / Low Frequency Voltage Signal CD Changer Left
7 / Low Frequency Voltage Signal CD Changer Right
8-10 / No Connection
kleuren op een rij.
BR bruin
GE geel
GN groen
OR oranje
VI violet
GR grijs
SW zwart
WS wit
RT rood
BL blauw
TR transparent
ik heb deze lijst weleens gemailt voor aanvulling voor de diy.. maar blijkbaar vinden ze dit niet informatief genoeg
12 / Brown / Ground
1 / / No function
1 / Tape left +
2 / Tape left -
7 / Tape right +
8 / Tape right -
9 / No connection
4 / Telephone Mute
7 / DAC - i-bus
15 / Ground
17 / Not Used (LAC)
x18805:
Pin No. / Function
3-4 / No connection
8-9 / No Connection
x01037
Pin No. / Function
4-5 / No Connection
kleuren op een rij.
BR bruin
GE geel
GN groen
OR oranje
VI violet
GR grijs
SW zwart
WS wit
RT rood
BL blauw
TR transparent
//.00.-// > /.-////.-///.-
Voor de duidelijkheid:
Beste Chris,Chris schreef:autos vanaf 2001/2005 bm54 conector met vlakke pinnen!
12 / Brown / Ground
1 / / No function
1 / Tape left +
2 / Tape left -
7 / Tape right +
8 / Tape right -
9 / No connection
4 / Telephone Mute
7 / DAC - i-bus
15 / Ground
17 / Not Used (LAC)
x18805:
Pin No. / Function
3-4 / No connection
8-9 / No Connection
x01037
Pin No. / Function
4-5 / No Connection
kleuren op een rij.
BR bruin
GE geel
GN groen
OR oranje
VI violet
GR grijs
SW zwart
WS wit
RT rood
BL blauw
TR transparent
Ik heb zo een digitale Yatour cd wisselaar gekocht waar ik een SD, USB of AUX op kan aansluiten. Ik heb deze besteld van het internet met de 3-pin en 6-pin stekkertjes die perfect passen op de originele stekkers van de cd wisselaar. Nu zit er ook nog een rode ACC kabel bij. Deze zou op de geschakelde 12V moeten. Ik heb heel internet afgezocht en vond elke keer opnieuw dat deze op de paars/witte kabel zou moeten. Als ik deze aansluit gebeurt er niks, maar als ik deze op de rood/groen aansluiten van de BM54-kabelboom of rechtstreeks op de accu dan werkt die perfect maar heeft wel mijn batterij leeggetrokken.
Heb je misschien een idee welke andere kleur kabel ook geschakeld is? Of MOET het de violet/white zijn? Dank je
